map sensor? (turbo)
Car  Clio 172
have searched the forum for the answer to this but cant seem to find anything!
on turbo'd 172s are people running meg 225 map sensors ?
if not, what?
cheers :D
renault 21 turbos run 3 bar map sensors standard,even cossies have to upgrade from a 2 bar sensor. dunno if thats any help
Here's the part number for the one used by ktec in the low pressure kit, I'm sure it is a 21turbo part
7700106886
This should give you scope upto a bar of boost so should be fine on a low pressure set up, however if your going high pressure just buy a genuine marelli 3 bar sensor.
trust me both ph1 and ph2 renault 21 turbos run 3 bar map sensors as well as green injectors
