Massive brake humming when braking from 100mph
When I'm travelling at high speed (100mph) and apply the brake I get a lot of judder through the steering wheel and large humming noise.
This only happens at high speed.
Any ideas?
Id take a guess at warped discs considering ur sayin u get alot of brake judder, if ur gonna brake hard from high speed invest in some good discs that will last longer
Fred found this to be near side rear disc. It was fitted incorrectly and wonky. So the disc is knackered as well as the pads.
The rear disc spacer washer thing has collapsed as well as the bearing.
So just a new rear brake set both sides
Pads or discs might be glazed so the friction isn't there. I get this on track after about 10+ laps. That's with ds2500s. Cooling would help. We assume this is on track yeah ;)
