Matching Inlets - what to use as a guide?
Si
  RS Clio 172
Hi :D
I have aquired an inlet mani off of a very kind northern friend of mine with a broken tb'd 172 :(;)
I'm looking at matching them all i need to know is what to use as a guide? I've read that holes in the gasket are larger than required so they can only be used as a rough guide, would that do?
Sorry i haven't searched but i'm in a hurry as it's lunch time. lol.
Cheers.
  rps13
Could you not put engineer's blue on the head and machine out the mani with a dremel?
Plenum the same?
Si
  RS Clio 172
iirc the plenum doesn't need doing?
also i'm not sure if blueing it up would be clear enough. wouldn't transfer that well surely?
Si
  RS Clio 172
If i were to use a gasket as a guide does anyone know roughly how much bigger the orifices in the gasket are in comparison to the inlets in the mani?
