Misfiring and running on 3
Car  Ford Focus RS
Hello wondering if anyone can help. My brother has had some running issues with his 182, kept misfiring and running on 3 cylinders and the eml light was on. I suggested he took it to AMD essex where I take my RS for any work, with they done a full service (which more importantly they changed the spark plugs). After this the car run better but now about a week later it has started its old problems again and the eml light has come back on.
Would you suggest HT leads and coil pack next? Any recommendations or other suggestions?
i dont know if this makes any difference but the only performance parts fitted is a K&N induction and a Miltek cat back
Many thanks
Get it on a machine and plugged in so it diagnosed properly. Otherwise you'll be changing
Coil pack
Leads
Plugs
Injectors
They all fail at some point though.
My money's on injector
Where would you suggest sourcing the injectors from? Had a quick look but I don't really know what Im looking for
Ring Adam on 01902 439264
Works at the renault parts supply base and will be the cheapest you will find (new)​
Id say its the Leads... I had this problem twice on my ph1 around this time of year, it seemed to be the cold and wet weather that caused the problems.
I sourced a 2nd hand lead off a member on here which was fine, then a few weeks later another went so i just replaced the lot... No problems again since!
I agree with DannyR though, get it looked at before spending money on things you dont actually need to.
Best of luck!
