Mk 2 172 Engine Mount
think mine is just starting to go, one of the lower ones i think, i have herd the most common one to go is the one that is shapped like a dog bone ?
has any one had theres changed ? any idea on a cost for getting it done ? i think the part is about £43 inc vat from renault. ??
many thanks in advance.
yes, but i don't know which mount it was. I'm about as mechanically minded as a tea bag.
i got mine changed last month at the cost of £160 which not sure if thats good or not.
Dogbone is a common failure only as said £40 or so easy to change 20 minutes tops only 2 bolts hold it on.
you where had! i changed mine myself for uprated powerflex one cannot see why it would have cost that much, no more than £100 MAX! surely
justin how did you know your mount was going mate what are the factors noises etc etc cheers buddy need to know if mine has gone as i was told it was the driveshaft but it wasnt
well under hard acceleration from standing, in 1st gear , there is a vibration from the engine bay which is intermitant. before i order any bits though i will get it checked out.
any news mate dont think mine is the same it is not intermitant it is a harsh knocking noise from the front passenger side that only really happens if you are on a hill and you go into reverse and lift the clutch to quickly and same when pulling away on the straight in the morning..what could this be guys?
