Mk1 16v brakes
B
Bluersi
Does anyone know if there is a difference in Mk1 16v and RSI brakes? Are 16v calipers bigger than RSI or is it just the disk size thta's bigger on the 16v? Can I just fit 16v disc's and pads on my RSI?
RSi use the smalelr caliepr and disk you need the caliper the caliper to hub bracket and the bolt (often) to be able to use the bigger Lucus caliper and 259/260 (they can be called both) disks.
