mk1 clio rsi/16v brakes
mrl
Car  clio rsi, clio 172
can some tell me if mk1 clio rsi brakes are diffrent to 16v brakes?
iv bought some brakes which iv tried to fit today and the discs are too big? so im guessing they have sold me 16v discs instead of rsi discs??
the new discs measure 250mm.
can someone tell me if there are 16v discs and would i just need caliper carriers to convert them or are the calipers diff as well??
thanks
yes mate 16v are slightly larger,i had the same problem i got sent rsi discs for my valver and were to small.
no 16v calipers don't have carriers the hubs are different just send the discs back and get the right ones.
rsi 238mm
16v 258mm
all cars have calliper carriers!!
ok so i need 16v hubs!!damm! i was planning on doing the 172 brake conversion at some point so looks like i might b doing it sooner than i thought!
erm??? you can bolt 16V/williams calipers/carriers straight onto an RSI, what crack you lot somking?
rsi - 238mm disc
16v/williams - 259mm disc
check with danny sideways, he's more of a mk1 expert than me
rsi - 238mm disc
thanks mate
i was hoping that the calipers were the same and that i just needed the caliper carriers which a bigger to alow space for the bigger disc's??
yup, caliper the same, carrier is different. I have still got tiny rsi disks on mine, becuase i have a pile of brand new disks that barely fit anythign else but 1.2's
infact I bvelieve you could fit calipers off a mk2 1.2 16v
Hello.
Can anyone write part number of caliper carrier for 258mm disks? Or Clio model name like C/B57_ for better find this carrier.
Thanks.
