Mk1 Dash Wiring/Lights
Car  Corsa C 1.4 SRi
Can anyone tell me how easy it would be to fix wiring on the dash, and replace the bulbs?
I think the wire to the bulbs telling me when my headlights/sidelights is loose as they come on and go off at random occasions (really just the sidelights but the headlights aswell) and i know this is an MOT failure. :dapprove:
Also the left side of my dash (speedometer, petrol gauge) is quite dim, and the other side (revs, oil) is fine. I think its just lights that need replacing.
Is it an easy job? :)
Bulbs are too dificult on the dash clocks chap, whip the dash top off, steering wheel surround then you will have access to all the screws to realease clocks (two top two bottom). Unplug all wiring and sppedo cable and the clocks are out!
So if the lights on the dash dont come on telling you that your headlights are on its an MOT failure? you sure?
Amir
Cheers, so i'm best just going to a scrappy and getting clocks there?
Yea the haynes manuals tell you what they fail on and so do some sites, you have to be able to tell your lights etc. are working :dapprove:
Pain in the tits
cheers, just had a look at the haynes manual, seems easy enough to sort. What type of bulbs are they? and where can i buy cheap bulbs? :)
these are the bulbs u need there are 2 types these are the smaller ones i think u need 21 of those but dont quote me on that my memory is pooor
http://www.m-99.co.uk/Car_Neon_LED_Lighting/Dashboard_LED_Bulbs/dashboard_led_bulbs.html
then there are the larger ones which are wedge type fitment which slot into the black bulb holder which in turn screws into the back of the clocks
