yeah it is leaking through your ariel had the same problem on my megane either bodge it and put silicone in without taking anything apart or take off the unit where you window winder is and put silicone in there and then put it all back in and will all be sorted
I took the roof unit off but you can't get to much. I'll take aerial off and sillicone that before squidging it back on. See if that helps first. Thanks.
