94' Valver F4R'd
That looks good with disc, but Dont think its worth it :/
Yeah 195/45/15's are so much cheaper but If I go to 15's I'll want decent wheels, Williams or Turninis
So If i can pick up a set of Williams calipers for the front, 5 GT turbo Caliper carriers, what size disc should I have? Mine are currently 238mm SOLID discs. Are Williams/16/5GTT brakes for Vented Discs?
Will this pretty much bolt on and need bleeding? Do I need a new Master/slave Cylinder? Brake lines?
Sorry for asking so many questions!!! Help is so much Appreciated! Finally getting somewhere!![]()
My MK2 1.2 runs the 259mm discs and 14" wheels fit without any problems.
With ABS,vented 259mm.MK2 1.2 brakes were also used on the 1.6 16v's. With uprated pads you'll be fine i'd say.
