Hi all, I've been having some issues with my car this last week. Hope someone can steer me in the right direction. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Firstly, has anyone experienced a knocking noise coming from the alternator bracket and front of the block, gets no worse when you rev it up and is at its worst when the car is cold.
Secondly, just yesterday had the inlet off for a plugs change all went well until I put it back together and running... Service light was on coupled with traction control light? So done some research on here and it seemed the issue was the brake pedal switch so shot out for it, fitted it and a half mile down the road the engine management light popped on aswell.
Then today all the above lights were still on, not affecting the car running wise besides it now idles a little harder than normal about 1100 revs or so. Anyway the ABS light has now made an appearance too.
Any help or tips would be greatly appreciated as im at a loose end.
Thanks Matthew
Thanks Matthew
