mk2 clio 1.6 stalls at start
Car  Clio mk2 ph2 1.6
Hi there, when i start my clio it ticks over at a very low rate and most the time stalls unless i rev and will carry on till i have driven for a little while. Once warmed up though it isn't a problem. It seems to be getting worse. Any ideas?
thanks in advance for any help!
Hi thanks for the reply!
Any idea where the throttle body is on my car and how to take it off?! I have a 1.6 51 plate mk2 ph2. I have searched the forum and nothing substantial came up. I also googled and some guides came up on "renaultforums" but the site appears to be down.
at the back of the engine is ur airbox with 2 E8 bolts through the top. remove them and push the airbox back. that silver unit is ur throttle body. theres 2 10mm bolts underneath the throttle bodyand 1 on top. its a bit tight because with the airbox off doesnt give u much room but its easier than tryin to take it out!! hope that helps.
Hi thanks so much for your help already but one final question :P
which are the bolts im undoing:
u need to undo the 2 rusty lookin bolts in the picture first. take them out and then u can push the airbox back away from the throttle body. then undo the 10mm u see in the picture and theres 2 10mms under the throttle body that u cant see in the picture. undo them and then the throttle body will come out. hope ya get alrite!
Cheers mate thanks so much for your help! Ill have a go at it tomorrow and let you know how i get on!
