mk2 ph2 172 rear bumper on ph1 none 172
Car  A number of clios
as anyone done this?? does it fit and hows the fit im looking for a different back bumper for my ph1 1.6 and quite like the ph2 172 bumper if its not a good fit ill just stick to the normal ph2 bumper i no these fit ok
think u need to speak to a guy called HAS.............me thinks :cool:
Saner's is a 1.4 Day I think but either way it's irrelavent! Haven't you got a ph2 172 rear on yours Day? If so fitting would be the same, sport or non sport. A ph2 172 will fit exactly the same as a non sport Ph2. They will fit you just need to drill a couple of holes as they don't line up. Do it mate.
Yep I've done it, the holes don't line up under the boot hatch, but everything else does. Pretty much a straight swap.
Could be a straight fit, Saner asked me if I had to drill holes because he did but I never had too.
My car is a late Mk1 172 so it has a few bits from the mk2 on it - it's a bit weird and a nightmare getting the right parts sometimes!
Here's mine:
I find with my 182 bumper, everything lines up fine but the very edges of the bumper don't come into line with the wing quite right and just stick out a little bit. That may just be the way it was fitted though...
Hey guys, on my Mk2 Ph1 1.4 I had to drill holes and the lower support holes don't line up by about an inch. Can take pic if needed
I did it by hand and very carefully, surporting the bumper in amyway that I could, have no problems since as far as im aware!
