Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
hi guys, got some phase 2 lights for my mk2 ph1 just wanted to kno if anybody actually knows how to swap the wiring, jus dont want to break the connectos, diagrams would be helpful thanks.
There is a plastic flap that covers the connectors - snap this open and you will see all the connectors underneath. Turn the connector round so the wires are comning out the top and put a bit of strain on the wires - Using a terminal screw driver flip the small tabs outward on the back of the connector - repeat for every wire and one by one they will pop out and can be removed from the connector. Insert in the correct order - See V6 rear lights thread for table. Click back down the hinged plastic part and repeat for the other side. Takes 10 mins max.
