Mk3 clio drivers window
  Clio mk3
Hi just wondered if anyone has any idea what this might be, my drivers window on my mk3 clio, if it's been up for a while when I go to open it it seems like it's slightly stuck? Goes up and down fine just wondering if anything could be causing it to have difficulty opening smoothly after being closed for a while? Any ideas? Thanks
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Dirty window channel. Clean it out and maybe give it a quick blast with some silicone spray.
  Clio mk3
yeah i thought it might be a bit dirty, seems to have a bit of mould or whatever in there, any advice on the best way to clean it out? never had to clean out a window channel before so dont want to end up damaging anything etc
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I use brake cleaner and a tough bristled brush for things like this... i use brake cleaner on most things lol
  Clio mk3
haha yeah sounds good! just wouldnt wanna get anything strong on the paint/rubber seals etc that may damage it! but ill have to pick up some silicon spray next week and give them a good scrubbing! is it worth going around all the window seals or just the side channels where the window comes up?
Wouldn't bother with the silicone spray! I did this to mine and it just smeared the window up like crazy every time I moved it :( Only did it to stop the squeaking seals!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
You don't go full r****d and spray it everywhere. Just a small application on the upper edge will be enough to allow the contact point to pick it up!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Are you after a scientific/physical measurement? The smallest dribble is all that would be needed, just use common sense... you won't break anything just make smeared marks on the edge.
