Money To Spend, What To Buy?
Car  Mk2 Ph2
Thought id treat the car to some new stuff so was havin a gander at what to buy and was looking at the following,
1 x Menzerna PO 85 RD3.02 - 250ml
1 x Menzerna PO 203 S - 250ml The £22.99 pack
1 x Menzerna PO 85 RE 5 - 250ml
Stuck between what pads to get either:
3m high gloss yellow polish pad
3m finishing pad blue
Or
Lake country white polishing pad
Lake country blue finishing pad
Have a kestral das6 btw and the car has some swirls on it nothing major though
Hey mate. You don't need all that polish. Try the menz 203's get some hexalogic pads with decent cut.
Hex pads are very good on the da. The others aren't as good.
A cleanser like werkstat prime. A glaze and a durable wax. :)
+1 for the hex logics, i like menzerna but lime prime and a glaze and then a wax and you would never even see the need for the polishes
depends how much correction or cut you want to acheive, yellow being the most aggressive (heavy cut), orange a little less (light cut) green is heavy polish, white is light polish etc etc. others are for finishing and glazing, says it all in the CYC descriptions, dare say it also says it on CG direct
okay cheers for the help, gonna order the green and orange pad, hopefully that will remove the swirls with menzerna po 203 s and other products ive got,
