Yes the size of the inlet to the tb is a factor, but that's not what this mod is addressing, this is addressing the restriction in the feed. Once this is done you can work on the rest as you could also say ther's no point sorting out the inlet pipe without sorting the feed to the airbox.
I've just disconnected my standard feeds and will have a run out later with the RSTuner unit all plugged in. Will do a few runs up and down the DC, then will connect them up again and try again. I'm hoping to see that without the feeds the manifold pressure isn't dropping anymore. Not bothered about air temps for this test, I purely want to see if the standard feed is causing my pressure drop.
If you take the light off you can cut away a lot of plastic from underneath it and then position the feeds right behind the vent.
Is the filter element clean, ChrisR? All the same this should be interesting.
Are you offering re-maps, is that what the RSTuner unit is for?
