more depth
Car  Trophy #473
I want a bit more depth the my sterio, theres nowt wrong with the standard one in my 172, but i just want more bass, How can i wire up a small sub/amp combo to the existing sterio, dont want to cut loads of wires tho, can i take a feed off a rear speaker to feed the amp, I suppose the amps LPF/HPF i forget which one does what, will remove the high frequences. only want something like an 8" sub.
nathan
not ideal to run any size sub without an amp, the sub sucks a lot of power thats why they run direct from the amp, i would suggest doing a boot job there not hard and if u jusat do some homework then you can have it fitted in 30 mins from scratch, i got a 10" sub and amp with all wires and if you fancy coming somwhere up northeast way then ill sell you it and fit it :) £50 is a steal :P
sry read the post wrong you want to take a power feed, yea you could but im sure sumet to do with the fuse will fuk things up if anything goes wrong,,, make sure you have a really good earth then it shud be ok
