more GDI 16v engine pics
  GDI Demo 182, Rsi Spider
clio mate, breather mods and no carbon canister.... no outlets not needed in same place.... also moving the idle control valve so its usefull to use the 19 manifold... other than that they are identical
strange, our one mounted fine with all the brakets.... its all supported and connected fine! end of discussion really....
99% sure that the inlets will fit fine.... when I measured it was ok... nothing a large hammer cant sort...
our engines are colourfull becuase that is what the customer has asked for... + I like to pretend I am still 10 yrs old and playing with lego
  300bhp MR2 Turbo
Andy,
What kinda time and cleaners/paints go into making an engine look as mint as that.
Mine works fine but who ever designed it would have a heart attack if they saw it, 11 years of wear and grime!!
  300bhp MR2 Turbo
Ha ha!
It needs those multi coloured little things that go around when its moving, like in the lawnmowers!!
  20VT Clio & 9-5 HOT
mint engines. Seems like u do a good job mate, definately keep u in mind for any further work!
just for info guys, the 19 manifold worked fine on the clio engine above that it went into..
  350z & 16v Maxi
excellent, that means i can use my 19 manifold then. Can use the injector cover tho, anyone know any nice injector rails that will fit the Clio?
  350z & 16v Maxi
cool, might just get that done to the injector rail too, already getting the manifold and the rocker cover done
more importantly make sure the wiring loom over the injectors is neat and tidy.... that sits above the fuel rail and is more visable
