more power and quicker gearbox ratio's from my 182!!
Drewk24klio
Car  clio 182 cup
hi. got a 2005 182 cup rally car, engine has throttle bodies but nothing else. it has a standard gearbox but with an ATB LSD. i done my first rally and beat a type R but i am after more power. i have heard that the head off a megane turbo as it has bigger ports etc, is this true? is there any other parts i can use off other renaults to get better performance? also can the 6 speed gearbox from a 197 fit? do they have an LSD? i dont want to spent stupid money on a sequential as im not going to do that many rallys.
any help would be appriciated
many thanks!!
Hey, PH1 172 have bigger exhaust ports in the head so might be worth considering along with some Shrick/Cat cams. This will cost roughly the same as http://www.cliosport.net/forum/showthread.php?596482-F4R-Engine-Building Considering you already have have ITBs these packages could show some very good results.
Regarding gearboxes Burpspeed on here are running a shorter 5th gear ratio check there thread out. 197 box will be hard to fit, the casting is different on the 197 block so will need a custom bell housing.
