MP3 help
Right Ive got a portable mp3 player and I want to connect it to the standard head unit. Is there a waty I can connect it to the CD changer input, if thats not possible then is there any other way. (Apart from using one of those tape on a wire things!!) Cheers!
Tom
  i3
oh dear
ok
get said head unit and remove it
set fire to it
and buy a new headunit
or use a tape thingy (if you must)
I had a new head unit but some theiving bas**rds smashed my window, nicked it, and damaged my dash, now Im out of pocket 350 notes, so Im not willing to have that done again!! There must be a solution!!!
Tom
  i3
you could find the audio in feed on the changer input but it would take weeks to figure out a way to do it
you could amp yur speakers through the high level inputs in an amp and have a rca in to the amp and play mp3s from your player into that
Hehe tom, i found that amusing:)
oh dear
ok
set fire to it
right I wanted to ask exactly the same question... I have the standard CD/radio with a 2002 clio, with I have a changer fitted as well. I just bought an ipod and it would be superb if i could link it to the car stereo. Is this possible?
Tom
  i3
if the cdchager uses the standard alpine connection (ai-net) you can get a box that gives you a extra connection input but the hu wont support it
the only way is to use fm modulation which should sound better than using the tape thingy
