my 1.2 16v
right i was just wondering if this sounds normal, i rag my 1.2 16v alot (mainly hoping it will go bang then i can get my 172 conversion with the mrs say so lol) and this are how mu gears go,
2nd 60mph
3rd 80mph
4th 100mph
5th 115mph so far,
now these are with my foot on the floor and the revs going to 6,800ish rpm, on my private runway of course,
are these normal speeds for the grears,
all i have had done is totally stripped the rear, i mean totally, a magnex 6x4 zeust and a panel filter,
its a 2002 51plate and on 34k miles,
( also would a decat really do much? and is it worth fitting one then havind to swap everytime for a mot?)
ok, mine has got to the 115 mark and i lifted off, doubt it would have gone anymore tho, also dont kno how aCCURATE THE SPEEDO WOULD HAVE BEEN
I did that a couple of times in mine mate, but never again... 1.2 over 100 is wobbly to say the least.
with bigger wheels it puts the speedo out, mine on 16's is 5 miles slower than the speedo says!!
My 1.6 used to do about 57 in second on the limited and the 1.2 is the same, seems to be the exact same box.
JC7 seems to ring a bell.
Yeah mines the same, my limiter is at 6,100 my max top speed is about 110 on the standard 14" steelies, takes a while to get there though! and if theres a strong side wind i get blown all over! lol
mine limiter kicks in at 6,500k :) Also you say your 1.2 weighs 875KG? what weight reduction have you done to it?? becuase if its just the rear seats and carpets etc all that wont take off 200kg??
They use different boxes, the 1.2 uses the JB1 box and the 1.6 uses the JB3 (mines a JB3 979) due to the increased torque it produces. The ratios in the 1.6 are slightly higher than the 1.2.
mofo what MPG are you getting ragging it that hard? even just taking mine to 4k/5k revs in each gear on mine drops it way below 25/30mpg:S
26/30 mpg so not alot lol, but if i drive nice a slow i can see 50ish,
also mine is completley stripped, all thats in is front seats and front door cards, everything else is gone, ie carpet,spare wheel,seats,plastics the lot,
to loose a bit more id take off the front and rear pads, headlight bulbs, brake lights, washer yets, wipers,
then try and see what top end you can get.. best to try it at night as the roads will have less traffic
^^ ha ha ha
well mine is doin 44mpg, and that was a rag up the motorway, and if i drive it quick it rarely drops below 38mpg!
lol you funny guy,.
No way you've saved 200kg from just taking the seats, spare and the flimsy plastic. I had all mine out in a 182 and it only came to 28KG without the spare.
thats what some one off here said the weight was lol,! i never acutally weighed it all lol,
<------------------------------ as you can see i have ammended it,
Will the engine from this:
fit in my 1.2 16v?
i havn't got it no more, was taken on my phone but i had 120 out of it a fair few times.
Literally held it pin'd down the M6 toll for 3 miles mind lmao....
lol hahaha :D coooorect!! just rememberd it done that thing with the clocks so run out and took a photo :p hehe
