TBH no matter how much you complain to AOL they wont do anything. I was ringing up complaining pretty much every other day for nearly a month as there was blatantly a fault on my line and they fed me the same bull s**t every day, I'd ring up and they would do a line test, and then say they would send out an engineer, which they never did. Complete tossers.
what speed are you synched at? and what is your bras profile currently? oh and your line attentuation and snr. you might be a fair distance from the exchange. Or you may have had a power surge or the like which has caused a massive amount of hec/crc errors in a small space of time causing bt to lower your profile to suit, happens often
dont kno what the above are fiXX WILL REEBOT ROUTER NOW AND SEE, I USE A WIRELESS NETGEAR ON, ARE THEY NORMALLY s**t AS I HASE MAINLEY BEEN SINCE I CHANGED.
netgear dg834pn is a good netgear router, you can even fool the exchange into thinking your snr is lower with that router efectively letting you choose your own bras profile
You've been capped. You must have downloaded WAY too much in the past few weeks/months and AOL have restricted your download speeds. Its because ISP's have a fair usage policy and if you exceed their download limit your download speeds will be reduced. I downloaded over 100gb's of stuff within a few days and had exactly the same symptoms as you. During the day and after 11pm its spot on, but peak hours you will be capped to around 50kb/s or less. Cant do anything about it other than reduce your downloads and wait until they re-assess your downloading. Keep phoning them to request it be lifted.
Well that why I was capped. I was downloading everything from newsgroups. They didnt like that. After several phone calls I've now got my speeds back up. Around 4500mps now.
nah you aint capped, that only affects peak times anyway and that still wouldnt explain your ridiculous ping times, i reakon its a line fault, try setting your own dslam as i said in pm if you still got no luck try the bt site to check if you have a line fault, you can do it yourself
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Compaq_Owner>ping bbc.co.uk
Pinging bbc.co.uk [212.58.224.131] with 32 bytes of data:
Reply from 212.58.224.131: bytes=32 time=25ms TTL=117
Reply from 212.58.224.131: bytes=32 time=18ms TTL=117
Reply from 212.58.224.131: bytes=32 time=17ms TTL=117
Ping statistics for 212.58.224.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 17ms, Maximum = 25ms, Average = 19ms
Is that any good? I'm with Telewest and all i know is a few years ago i went on to 512k from 56k, And I haven;t spoek to them since, I think its upgraded itself a few time though now
