Bit of a no go me and gearboxes, is this sensor, does this mean its not driven by ABS? Taken the metal heatshield off it...
Speedo driven, Early PH2 172s have them
Phase 1 has a longer final drive
Is this gearbox issues since the ITB's were fitted ?
Can't handle the power ?
Not bad, iirc its about £285+vat for a rebuild from the bloke near me£250 delivered, fully rebuilt 17k ago.
Not bad i dont think
Nah, it was f**ked before, been like this for about a year, ive just been putting it offJust been getting worse, as i do give it death tbh.
Lol
Where did you get this box from ?
182 box won't work then!
Are you on about the guy in Worcester Burp?Not bad, iirc its about £285+vat for a rebuild from the bloke near me
bit funny this though, some seem to be setup to run the ABS sensor for the speedo, even though they have a gearbox sensor. Not sure why.
Yep, he showed me a ruined diff he took out of another CS members box a few weeks back. Fitted a new diff, some bearings and a syncro for aout 300 notes.Are you on about the guy in Worcester Burp?
I was there today with Gray. Dropped two boxes off to him. The guy seemed very knowledgeable about what he did ( well both of them did ).Yep, he showed me a ruined diff he took out of another CS members box a few weeks back. Fitted a new diff, some bearings and a syncro for aout 300 notes.
Can't fault him
in our crypton scanner you can alter it to take the speed signal from speedo or abs...not what i meant, seen them with a fully functioning sensor in place, but the speedo doesn't stop working when you remove it
Can't fault him
Did he do you a good price? Mention you knew us?
on a 182 danielsan?
