Need help please
Els
Car  Inferno 182 Cup
Got a 182 cup and I went to take my alloys off today so I could clean the inside of them.
I got the 4 bolts off but then noticed there was a big ass nut in the middle.
What size socket do I need to take it off? also Is that the only thing holding it in place after?
If you could let me know that would be great!
REALLY want to take them off the car to clean them proper.
Mines not a cup but all I have to to is remove the locking wheel nuts and the wheel come off, are you sure the middle nut needs to come off to get the wheel off?
I rocked the wheel back and forth like they do in tyre places and It would not come off.....
Does yours have the nut in the middle?
It does have something in the middle can't picture it but Im sure its not related to the wheel!
maybe it had rust on the hub, it will come off els, & you dont need to take the Castle Nut off, as that releases the Driveshaft,
Think what your decribing is called a hub nut, if you were to undo that you'd ideally need to torque them back up.
Which wheel are you trying to get off?
have you jacked the car up
HMMMM yes I have LMAO!!
went to have another look and it looks like a bit of surface rust, nowt big. So hows the best way of getting the wheel off then?
got the pic but imageshack being a bit of a turd at the mo...
Just undo the four wheel nuts, don't undo the large centre nut. If you have messed with the centre nut then get it to a garage to get it torqued backup correctly.
seriously mate jack it up (;)) take the bolts off and yank it
pussy :rasp:
you could always get under it with a rubber hammer ? :D
Na I aint touched the center nut.... left it well alone...
Here is a pic.
once you get it off put a tiny bit of grease round the rusty bit so you can get it off in future.
Thanks everyone, off to WD40 it now :)
Will post some pics of them up in this thread tomoz once ive cleaned them :)
block of wood on rear of the rim and hit the wood with a hammer it will come off then.....
give it a kicking,, they can be a mare sometimes its jetwashes that do it.
jag wheels seize on big time takes out 6ft bar to lever the feckers off
Just sprayed some WD in there now.... just hope the rain dont get rid of it all.... s**t HOUSE RAIN!!!
