Need help with replacing rear discs
Car  Renault Clio 172 Ph1
Hi,
I am trying to put new discs on the back of my Ph1 sport, they came of easily but now that i have put the new ones on I can't get the pads in as there is not enough space. I can see there is 2 bolts at back of the caliper, and they are covered by rubber it looks like they can adjust, is this so or have I forgot to do something. Or is there something I need to do. Discs are the right ones so are the pads, had new wheel bearings fitted at garage.
Plaese help
To remove and refit new pads you need to tap out a little bar/spacer. The spacer has a little wire clip holding it in place.
Once you have tapped this out, install new pads in the carrier the tap the spacer back in.
