Need quick answer ;) copper greasing guide pins?
Car  Valver
As above, Im sure I read sumwere that you shouldn't do this? IE take the pins out grease em up then put them back in again?
Yes you should put copperslip on the guide pins, otherwise the carrier won't slide in and out smoothly. :)
copper grease is only a anti-seize compound though? should I be using some kind of grease then :S
^^ lol I've had it over a year now and there isn't a point where it has ever been completely fixed :(
Worth changing the boots while you are there, over time they distort and let moisture in.
