New enine, non starter...
  Project: 54 clio dci
Alrite,
Have a little project on the go, a 54plate clio, im a ford technician so not so familiar with renaults!
bought with a knackered engine, replaced it... plugged it all in and it cranks and cranks but doesnt fire,
constant engine management light upon starting. until the stop light flashes as i imagine it registers a non start.
next port of call is a code reader, which im getting put on it. just wondered if you could throw and light on the subject.
the pumps do not need to be "learned/programmed" to the ecu do they before theyll fire? (this is the case with fords that i work on daily)
swapped the cam and crankshaft sensor from the old engine but no joy.
cheers guys!
  Megane dci 130
If its the Dci, the pumps dont need to be programmed. The injectors do on the other hand. Are they the originals?
Have you primed the low pressure side of the diesel system?
Done the cambelt before the engine went in?
