new exhaust leaking, help please?
J
jakm15
hi, i fitted a new backbox plus center pipe about 2 months ago and the clamp which connects to center pipe to the cat is leaking, it is 2 u shaped pieces with a nut and bolt at either end which tightens it up, when i fitted it i had to really rip it up to hold the cat and the center pipe together.
any ideas on how to sort this????
its a w reg 1.2 grande
thanks
  PH1 172
Are the clamps tight fitting around the pipe already (as in correct size for the bore size)?
Undo them again and make sure the 2 pipes are pushed together as much as possible and then tighten it back up again but before you do you could try some exhaust paste to seal any gaps.
J
jakm15
thanks for the help, ill go and have a look now ive got some free time. i think the clamp was tightish, ill go and have a go now and let you know.
