Hi there,
Just thought I would post pics and some info on the mods I have just completed on my 172 Mk2.
I did a lot of research, and 100's of emails later, phase 1 of my mods are complete.
I started off installing a 2.5 inch stainless exhaust system, including a high flow cat. I have a Scorpion muffler.
Next was the ITG Maxogen, as shown. I ran a 70mm intake hose from where the fog light used to be, removed the acoustic valve so the hose would fit, and ran it straight to the maxogen.
I then ordered and installed a Renault Sport ECU (Group N) from www.clio-power.org.
Mark was very helpful and answered all my questions, he suggested the mods above. The guy has raced clio's for ages, he knows what he is talking about.
I finally installed the ECU on the weekend, and what can I say.. It's a totally different car!
Heaps more torque and pull throughout the range. The 7800 rpm limiter is awesome. It just keeps going, the large exhaust and IK help the engine breath more at this point. When you change gear, the revs stay up above the 5800-6000 rpm range.
Drivability and throttle response have improved dramatically. Even my 17 inch wheels just want to spin when changing up. There are no more flat spots, I found it used to bog down on low revs, and go no where around the limiter.
2nd gear now revs to 110 km/h. The car sounds awesome! Nice deep roaring sound, and the popping from the exhaust when you let go of the pedal is a nice bonus.
I did a dyno run before I did these mods, it managed 134 HP (100 kw) at the wheels, and 140 lb/ft ( 189.60 nm) of torque. I'll scan the sheet when I do my next run, which should be soon. I'm not expecting huge gains, drivability is hard to measure I guess.
Next on my plans is to order a modified inlet manifold from BenR, and a fast road set of CAMS, then get it re-mapped using the SMT6. This should see it up around the 200 bhp mark, but more importantly, a heap more torque (170+ lb/ft or 230 nm) fingers crossed anyway.
I hope this helps you guys, if you have any questions, please fire away.
I'm well happy with it, at one stage (before I got the ECU) I thought I had just waisted a heap of cash.
peace.
portal from OZ.
peace.
portal from OZ.
