Nokia N80 battery life
change it over to GSM mode unless you are using 3G features
Saves a fair whack of battery life :D
yep same here!
I charge mine every other day, sometimes have to charge when on the phone to avoid it loosing battery.
Truely shocking
Easy
Menu => Tools => Settings => Network
then change Network Mode to GSM and select (willl restart phone)
If you require UMTS functionality, re-select Dual Mode or UMTS to regain 3G coverage.
RSi Dave said:
yep same here!
Truely shocking
m8 the battery life is dog s*ite, i have an old noka 3210 which i use just as much and charge about twice a week and the battery in that is like 5 years old
azzer2000 said:
how much more batt life will this give?
It will vary - its given mine about a 2-30% help
The latest firmware also has helped battery life.
