Non start 182
stevem42
  Silver182 and RB 182
Ok here goes hopefully some can help
Recently swapped engines on my 182 engine came from 172
Immobiliser light going out
Engine turns over fuel present.....bought Rs tuner no faults found on plugging it in
Swapped coil pack ....injector rail....... crank sensor
Still a non starter
Help please now I'm really lost....
Thanks in advance
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Fuel present but is it actually coming out of the injectors? Check all fuses and connections and report back
Mick
Engine turns over fuel present.....obd2 connector Rs tuner no faults found on plugging it in
Still a non starter
Thanks in advance
that is qute.happy every day
stevem42
Fitted it on borrowed clip today still no faults present......any help please
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Right firstly I need to understand the problem so lets start at the beginning for beginners. When you put the key in the ignition and turn it to position II (all power lights on), what is the "state" of the red immobiliser LED:
Flashing @ 1hz
Flashing @ 4hz
Solid (then OFF after 3-5seconds)
Solid (then on indefinitely)
Mick
Diamond Motors
stevem42
Solid then off 3-5 secs
It says on clip ......on with key turned off and and off with key turned on if that helps
Done multiplex everything ok
Fuel injection ok
Immobiliser ok
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Right so we've ruled out security and infrastructure integrity. Moving on...
... The basics - Fuel line off the rail. Turn key on but do not start the vehicle. Fuel flowing out?
Mick
Diamond Motors
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Okay, disconnect the coil pack, remove the INJ rail out and have it facing up with the fuel line connected.
Now crank the engine... Are the injectors firing?
(It would be far simpler to scope the injector triggers but I'm guessing you don't have a scope)
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Right, back in to CLIP you go and to PETROL INJECTION > PARAMETERS
look at the engine speed when cranking. Does it register a speed?
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
No rotation = crank sensor circuit fault... Investigate
Shows rotation = check injectors have +12v... Check fuses and wiring
Mick
