Normal Wax v's Wheel Wax?
Pep
Living Dangerously
  M2,XJS,S1000RR
Whats the main difference between the 2?
I want to get a few coats on my winter wheels today but only have normal Poorboys wax, is there a big difference?
aucky
Not particularly.
I'd go with Collenite 845 or FK1000 if you're not familiar with semi-permenant sealants.
Preparation is the crucial factor in durability though.
Pep
Living Dangerously
  M2,XJS,S1000RR
I've got to stick with what I have unfortunately as I want to do it this afternoon, was just wondering if there was a big difference in the 2.
Pep
Living Dangerously
  M2,XJS,S1000RR
Poor boys hardcore paste wax I think (or possibly chemical guys, I can't remember exactly and I'm at work)
  Golf GT & A4 Avant
typically a wheel wax will give better durability as it will hopefully stand up to the higher temperatures, but I've only ever used rim wax, Coli 476, AG HD wax and C5.
As long as you keep on top of it your wax won't do any worse unless you compare it to the proper wheel sealants from GTechniq, Nanolex, Cquartz
The difference being a dedicated wheel "wax" will be produced using waxes with a higher melting point (usually synthetic) to withstand the heat generated by the breaks that is transfered in to the wheels, this heat will premurturly break down most normal "body waxes". Thats the main difference, we go another step further in that we wanted a product the can be applied, and cure fully to be removed a wheel at a time, rather than having to go around all the wheels putting it on then back again taking it all off, so you can sit and treat one wheel at a time.
James
  133/225/CLS AMG
I'd imagine most specific wheel waxes are more like a sealant so a chemical wax as opposed to a lot of the carnauba based ones you put on the bodywork.
To be honest though as much as I like CG's Wheel Guard, I can imagine a sealant type wax like Collinite or Finishkare will do just as good a job.
Pep
Living Dangerously
  M2,XJS,S1000RR
Late reply, thanks for the info.
Suppose thinking about it now the heat thing is an obvious one!
I gave them a couple of coats so hopefully it will at least help with the cleaning over the winter!
It will just melt off, Joe. No chance it'll last until November, let alone through to New Year (unless its garbed and the wheels are not subjected to any movement/braking).
Pep
Living Dangerously
  M2,XJS,S1000RR
Hmm, I guess I should stop being tight and buy some proper stuff then.
Theres a few mentioned above but any particular ones to look at?
C5 if you're willing to prep properly (and by properly, I mean PROPERLY).
Mint Rims from James@AF above, Poorboys Wheel Sealant is very good, as is FK1000p.
