T TomBear Car 1.5 Clio Dynamique May 31, 2009 #1 ive chaned the bulb but still nothing cleaned up the contacts (as they were covered in green dried on s**t) and nothing if i do have to get a new bulb hodler any idea how to remove the old one and refit it or is it a case of cut the wires and re terminate
Has Car RS 182 - Black Gold May 31, 2009 #2 Common Problem! There is a connector on the holder which can be a pain to get off. You will need to clean the contacts on the plug also when you get it off. You can easily get it out by putting your hand up the back of the bumper and pusing it out. Nice and simple. Clean up contacts and you should be good to go, not an expensive part either, think i paid about £5+vat at Renault last year....
K koi ClioSport Club Member May 31, 2009 #3 Had the same problem the holder just unclips from the wiring. I went and got another bulb holder and it still didn't work, ended up cutting the wires and putting a new connector on.
