O/S Rear 172 ABS Sensor - Only available from Renault?
  E92 M3,172 track car
The car was diagnosed with an open circuit to the off side rear ABS sensor.
Rather than trace for a split, I thought I'd just replace the sensor.
I ordered one from GSF on eBay which their advert said would fit which it didn't, they then sent me the part number for the correct item which I ordered from my trusty motor factors. This also looks wrong.
When looking at the sensor on the car it seems to have a rectangular tip that sits above the ABS ring and I assume has the sensor on the lower edge to read the ABS signals.
The new sensos both have a barrel like tip with the sensor in the end which would appear to point towards the back of the hub when fitted.
Are these Renault only items?
Having checked the new sensor against the car, it's also wrong so this must be Renault only?
