Odd wobble
Getting a wobble only under acceleration (dip the clutch / throttle off and it goes away), rather than being through the steering, it actually shakes the car side to side between about 30-50mph in any gear - more pronounced under high rpm. Then same above 80, feels ok 50-80 though. Bearings feel tight, ARBs and TREs look fine, driveshafts/boots both look ok. Looks like passenger side spring may be half a coil short, so could do with replacing, but could that be causing the problem? Was thinking it could possibly be a mount on the way out - there's a lot of side-to-side play in the gearstick when in gear.
Any thoughts, CS?
-J-
  RS2'ed 172 Cup
Sounds similar to an issue I had with the cup.
Turns out I had an issue with the diff in the gear box :(
Symptoms were a massive vibration/wobble under acceleration unless driving very conservatively.
  182, SQ7, Trafic
Drive shafts, but also sounds like it could be gearbox side one, which if exploded could mean new box :(
-J-
  RS2'ed 172 Cup
Eugh, don't say internal. Was yours only in a certain mph range? Or all the time?
Do a quick search on my started threads ;)
Was only under acceleration, whole car felt like it was shaking to bits, ask James from stone automotive he sorted mine after I tried shafts, wheel and brake disc balancing you name it we tried it!
  Clio 197
Are your front wheels straight and true ?
I have had a snapped spring and it didn't give the symptoms your describing
