oil change
Remove oil filler cap
Remove sump plug with bowl under it
Oil drains out
Once most has drianined out remove filter (good luck on a valver) - access can just about get a hand in from top, or access from bottem.
Fit new filter, do hand tight and smear new oil ont eh rubber seal
Refit sump plug with new sump washer (pence from reno) (only if its a copper one), if its steal with a rubber washer on it just refit.
Refill with oil, will be just under 5ltrs.
