oil change!
guys were are the oil filters on clio 16v, also is it accesible from underneath or does anything have to be moved etc etc
james
Remove top of slam panal and pull top of rad forwards, and replace it with a FRAM filter for a williams, they have a nut on teh top of them to aid removal
Filter is ont eh front of the block, int eh middle
Its infront of the engine wedged down in about the middle of the car between the engine and radiator.
Its a pain to do. Best advice is to get a proper filter removal tool then you'll work you own way of getting it out I moved it above from up above then droped id down and work underneither the car to get it out.
Some people remove the bumper/radiator but theres no need.
