Hi again!
I've just spoken to a renault dealer - and he did explain that renaults are 'made to use oil' ...
he then went through what the clio sport 172 should be consuming, in terms of engine oil, inbetween services. He said that when some people come in for servicing, the oil does appear low, and sometimes the oil light is on - indicating very low oil levels.. He seemed to give the impression that it was acceptable for the engine to consume most of the entire oil reservoir inbetween servicing...
my service interval is every 12,000 miles, and the entire oil reservoir in a 172 is 4.85 Litres, so...
12,000 miles divided by 4.85 = 2,450 miles per Litre (roughly)
The technicians judge was that if your car uses more than a litre for every 2000 miles or so, you should start to be concerned.. this still baffles me because some of you in this thread seem to use no oil atall in that time???
I am going to fill up the oil to the top when i get my new oil container (ordered off the net so i have to wait) and see how much the car uses over the next 1000 to 2000 miles...
in the mean time i may get a oil pressure check etc done, not sure what else to do really! :dapprove:
