Oil leak found
rocker cover bolts maybe?
doesn't sound like they know the engine very well if they don't recognise the factory fit leaking rocker cover :p
The engine powering your 182. Leaking rocker covers are a common fault as Francois who assembles the engines in Dieppe likes lots of red whine before applying the sealant. ;)
and it's a cambelt of job to fix it properly. You might get away with removing bolts and applying a bit of sealer for a while, but it'll deteriorate again eventually
the special tool from renault to apply the sealer (and i'm not joking here) is a plastic tray and a foam paint roller, same as what you can buy in B&Q!!
Did they send the apprentice out for that tool?? I bet its crazy money to buy off them too.
