Oil leak found
Only has it done today so will check the drive tomorrow
The leak tended to be be near the drivers wheel area on the drive
  DON'T SEND ME PM'S!!
rocker cover bolts maybe?
doesn't sound like they know the engine very well if they don't recognise the factory fit leaking rocker cover :p
  172/1.2/E30
The engine powering your 182. Leaking rocker covers are a common fault as Francois who assembles the engines in Dieppe likes lots of red whine before applying the sealant. ;)
  Seat Ibiza
LOL
The F4R is the engine mate, just the engines code.
and it's a cambelt of job to fix it properly. You might get away with removing bolts and applying a bit of sealer for a while, but it'll deteriorate again eventually
  Lionel Richie
the special tool from renault to apply the sealer (and i'm not joking here) is a plastic tray and a foam paint roller, same as what you can buy in B&Q!!
  Seat Ibiza
Did they send the apprentice out for that tool?? I bet its crazy money to buy off them too.
