Just got my car back from the garage.
My oil leak was from the cam carrier pins.
Anyone had this before?
And the leaks happened after the work? If you had any done?Yeah that's what the garage (who are good and I trust them) said.
Is that what it went in for originally?
I guess it's leaking from the cam cover bolts. Welcome to the F4R ownership!
The engine powering your 182. Leaking rocker covers are a common fault as Francois who assembles the engines in Dieppe likes lots of red whine before applying the sealant.
and it's a cambelt of job to fix it properly. You might get away with removing bolts and applying a bit of sealer for a while, but it'll deteriorate again eventually
No gasket iirc.
Applied with a roller at assembly I think
Ohh, no wonder they leak then.
the special tool from renault to apply the sealer (and i'm not joking here) is a plastic tray and a foam paint roller, same as what you can buy in B&Q!!
