Oil Temp & pressure Gauges in 172's. What your readings ?
I have just fitted Oil Temperature and Oil Pressure Gauges in my 172.
And i'm using fresh 5w40 fully synthetic oil.
I was wandering if there is anyone else with these gauges fitted to there 172/182's ?
And if so what readings are they getting from them ?
By that i mean,
  • What Oil temperature are you getting with the car fully warmed up (running for half hour or longer) ?
  • What is the oil pressure reading at say 70mph in 5th gear ?
  • And the oil pressure at 4000rpm and 5000rpm ?
  • And what is the oil pressure at idle (just under 1,000rpm) once fully warmed up.
  • After a good rag/thrash ?
  • And what oil your using (to see if it makes any diference to readings) :S
As i want to see if my readings are close ;)
  '92 172, Lotus Elise
long overdue bump...
mine sits at 6bar on cold idle and about 2bar on warm idle
motorway is 3-4 bar and pressing on it can go to 6
I'll check my readings to yours when i refit the senders.
I removed them as they were leaking :(
