Clio sport 182
Hi I have recently bought a 182 and love it, however I have noticed on idle it seems a little bit lumpy but fine when you give throttle input.
I have also noticed that every 500 miles it’s doing half a litre. Don’t get me wrong I expect it to use some, but it seems to be abit excessive. The car does not smoke until your in the higher rpm as in 5500 plus it doesn’t smoke to the point where u can see it coming out the exhaust but there is slight blue haze around the rear.
My questions are:
A) is this normal
B) is there anything that is common to cause this wear? Valves? Piston rings? Etc
I will happily do the work to the car but I need to obviously have some understanding of what can cause this issue or if it’s nornal and to put up with it
My questions are:
A) is this normal
