I know its been covered before but never seen a post with a direct answer so dont flame me
Im going to be running a Omex 600 ecu so as far as i can make out the ecu will run semi stand alone needing
Direct Live
Switched Live
Earth
Coolant Sensor
Air temp Sensor
Lambda Sensor
Piggy backed into the CPS
What does the standard ecu still run.
Fuel pump
Fans
Dash
When removing the standard wiring is there anything that needs joined to complete a circuit ,or is it just a case of cut and cap all the unused wiring with shrink wrap individualy then tuck it back into the covering.
So far i have pulled all the unused (injectors,map sensor,air temp sensor,carbon canister )wiring back to the rear of the engine bay and had planned to terminate it here.
Direct Live
Switched Live
Earth
Coolant Sensor
Air temp Sensor
Lambda Sensor
Fuel pump
Fans
Dash
