ChrisR
Ok I've got a weird problem and it's got to the stage where I need to fix it
Occasionally whenever I used to pull the wiper stalk back to fire off the front windscreen washer jets the rear one would come on instead. Usually I'd stop and do it again and it'd then work.
But now it's doing it all the time, pulling back the stalk the rear washer comes on and the front washers do nothing
The wipers themselves still work as normal, just the washer jets that aren't working.
I had a little poke about to see if I could see anything but there wasn't much to look at, just the pump and the plug that goes into it. Doesn't help that Renault have made it really hard to get all the plastic covering off so actually getting down into the pump/reservoir bit is proving difficult. Looks like I'd have to take the wipers off but after undoing the nut that would appear to hold them on they just don't budge
Could it just be adodgy pump, I've no idea how the car splits things to send water to the back washer, does it use 1 or 2 pumps?
Any ideas?
Any ideas?
