Optional Extra Parcel Shelf with speakers??
  mx5
Just won an auction on ebay for a renault parcel shelf which included two speakers and two tweeters, apparently it is an optional extra on mk2ph2s?
Am i right in thinking that the wiring i need will already be there? If not what will i need to do to wire it up?
  mx5
  SchwepTek™
Yeh it defo was an optional extra as i remember seeing them in the local stealers.
The wiring isnt already there though.
  mx5
Ah, are you sure? The seller said it was all already there, which was one of the reasons I bid lol.
How hard is it going to be to wire up? Bit of an audio noob
Will i just have wire it from the rear speakers?
  A ANIMAL
Not hard mate - just run a feed from the rear speakers. don't bother with the tweeters though.
  mx5
Alright cheers for the advice, will have proper look once they arrive
Rich - Yea i will do, went for these as they look more oem than 6x9s etc, but wanted an upgrade.
Why would you want that shelf ?? Some ned walking past will see your speakers, pop your wondow & they'll be gone.
Never advertise your stereo !
  mx5
Yea thats why I chose this shelf over some 6x9s, they are a lot less obvious than 6x9s and as they look oem most will assume they just came with the car.
  Hondata'd EP3 Type R
You will only be able to run these speakers and your fronts. You will not be able to run your front speakers, rear speakers and your shelf speakers. This will show the HU internal amplifier a 2 ohm load and its only 4 ohm stable.
I hope to god you didnt spend half of what they are advertised at in that auction though!
  mx5
Mine was £21 lol
Bit gutted that i wont be able to run all of them :(
The guy just messaged me saying:
on the parcelshelf is a female block connector and in the back/boot somewhere there should be a male connector to just plug in and play, hope this helps,
may put it back on the bay and try to make some profit, what do you lot reckon?
EDIT: Also, will it make a difference that I am using an aftermarket head-unit and have an active sub wired up?
what active sub is it?
You dont need 6 speakers anyway. A clio is a tiny car, Some good quality amped componants up front is all you need.
Quality over quantity is what you want here.
it was an option extra and designed to replace the rear speakers in the door cards, has it not come with any wireing? I would have thought they would plug straight into the wires either side behind the door card
part number was - 77 11 223 604 - Rear shelf with intergrated speaker kit - two sub woofers and two tweaters 2*100w max speakers!
  mx5
Cheers for the help guys, really appreciate it. I got the impression i would be able to just plug and play with my current set up. I will put it back on ebay, and look at upgrading my current door speakers instead.
The sub is the 12" Mutant X one, not sure of the full name.
