ok for those of you with the same problem as me in the mk2ph1 with the led bulb only working when doors are open and not via the switch unless u turn bulb around..
i was looking at the osram dot it led's which is a push light.. same white light..
does anyone know how big these are? as i was thinking of stickin one up there as a map light in the car now the switch isnt working? n will it look silly?
shud be ok depending on size..
or has anyone found a different push light that they are using for this problem?
cheers
cheers
