Painting wheels
Never done this before - need to change the colour of some wheels.
Also need an idea of some products to use.
What's the easiest way of removing the original colour, apart from sanding....anything that can be painted on then washed off or similar.
Not too fussed about finish as they are going to be abused and track only. Will be matte black or just black.
From bare wheel,
Prime
Top colour coat
then lacquer.
If you want to remove the original paint, then I presume Nitromorse may help.
Or take them somewhere to be acid dipped etc.
Failing that it's sanding!
Nitromorse takes f**king ages!
Best off just giving the current finish a good roughing for the paint to stick to if you're not fussed about a concours finish
media blasting.
Can ask Gus to help/give you some tips if you want, he worked for Pristine wheels for 3 years
Cheers Dan, think I'll now give up on the 2nd hand wheels - far too much effort involved, first in obtaining an honest description whats bent straight etc and then prep'ing\painting, just going to get another set of the one's i'm already running.
