Pcd
  Clio 172 Sport
Could any1 tell me wot PCD stands for and wot the figures actually mean for example 4x100 et35? Also wot PCD is recomended for the Clio 172
Cheers any1
  Mondeo STTDCI
Would image Clio 172 is 4x100 same as other clio's.
Its to do with how many nuts there are and the spacing of them IIRC. the ET number is the offset of the wheels.
P.D.C stands for Pitch Circle Diameter
4x 100 means: four studs with 100mm diameter between the opposite sets of studs.
ET is the offset of the wheel from standard(center) in mm.
i.e. The face of the wheel with an ET35 offset will stick out 35mm out from the center.
I think all clios (maybe not the v6) have ET35-37
